Activity › Forums › Panasonic Cameras › HVX-200 auto audio level
Posted by Piotr Niemcewicz on April 12, 2011 at 5:18 pmauto audio level
how??Piotr Niemcewicz replied 15 years, 5 months ago 3 Members · 5 Replies -
Noah Kadner
April 13, 2011 at 5:03 pmEr sorry- it’s not that kind of camera. Professional = non-auto audio.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
Frank Nolan
April 14, 2011 at 7:27 am[Noah Kadner] “Er sorry- it’s not that kind of camera. Professional = non-auto audio.”
Well that’s not entirely true. There is a function called ALC (auto level control) in the recording set up menu which when set to on supposedly reduces distortion at high input levels, although it does say in the manual that it doesn’t change the audio signal recording level.
Frank Nolan
April 15, 2011 at 4:30 pmYes exactly, however when you are using the inputs 1 & 2 for external sources, the onboard stereo mic automatically gets routed to tracks 3 & 4 and if you have ALC on it does act as a control for the level of the onboard mic as there is no manual control in that situation.
Piotr Niemcewicz
April 15, 2011 at 7:02 pmyes, if you write in 4 audio track mode
only DVCPro 50, and HD modesbut if you work in DVCpro or DV or write on tape in DV mode (48 kHz)?
