Activity › Forums › Panasonic Cameras › hvx 200 720/p30 ?
  • hvx 200 720/p30 ?
    Posted by Timothy Early on April 16, 2010 at 7:14 pm
    why does the HVX200 have a 720/30p setting? when i have tested both the 720/30p and /60p they are the same in FCP…
    using a firestore set to dvcprohd/quicktime pn not p2s
    Michael Sacci replied 16 years, 5 months ago 2 Members · 3 Replies
  • Michael Sacci
    April 16, 2010 at 9:22 pm
    They are not the same, 30p records each frame twice, if you shoot 30pN the duplicate frame is removed or you can remove these redundant frames when you capture the 30p into FCP. 60p has 60 frames, will be smoother and can be converted into 30i perfectly. The only reason to shot 30p is to save on HD space, IMO.
  • Timothy Early
    April 16, 2010 at 10:56 pm
    Thanks Michael!
    Since i am using the firestore and basically transfer files i will stick to using 59.94!
  • Michael Sacci
    April 17, 2010 at 3:43 am
    You can set the firestore to remove the duplicate frames and by doing so you get 2x the record time on the device. If you don’t need the extra record time I would record 60p (59.94) If you need to down convert or upper convert to an interlaced format 60p works best.
