Activity Forums Apple Final Cut Pro Legacy HVX 200 @ 1080p30 and FCP Help
  • HVX 200 @ 1080p30 and FCP Help
    Posted by Jeremy Smith on February 12, 2009 at 12:28 am
    I posted this in the Panny HVX 200 forums as well so if you happend to read the cross posts my apologies.
    Hi all
    i’ve been searching the boards and I found so many different takes on this problem that my head has nearly burst. I’m still having trouble so I could really use some help. Here’s the issue:
    I shot a time-lapse of the tide for use in a video explorer (museum piece) and after researching the tech requirements I did the shoot at 1080p30 with the HVX 200, thinking that it was best to shoot progressive etc. Everything looks great but I’m having trouble setting up FCP to handle the footage without getting a nasty render hit. I tried the 1080i60 easy setup and change the field order to none with no luck. It always seems to want to log and transfer at 1080p30….then even if the sequence compressor settings change to 1080p30 I still have to render. I’m really confused.
    I shot with the HVX 200 at 1080p30 to P2
    I have FCS2 on a 2x3ghz Dual Core Mac OS 10.5.6, KONA 3
    Thanks for any ideas…I may have missed something but I’m freaking tired and resolutions/formats/frame rates have pushed me to capacity today.
    All the best
    Jeremy
    Andre D’elena replied 17 years, 6 months ago 2 Members · 1 Reply
  • Andre D’elena
    February 12, 2009 at 10:12 pm
    Try a ProRes sequence. Isn’t that what L&T transcodes to? I work with a lot of DVCPro50 P2 footage but not 1080p30. Good luck.
    Andre
