  • Posted by Chris Rust on April 7, 2005 at 7:15 am
    Aloha,
    I bought the new HDV camera and have shot some stuff on the HDV setting. I also got the M1U deck to go with my system. When I play back what I’ve shot set to down-convert to DV for input to FCP everything seems to be ok. When I check the clip in the Viewer, it looks as I would expect. When I drop the clip onto the timeline and look at it there, it shows in letterbox format. I selected SQUEEZE for the down-convert–opposed to LETTERBOX or EDGE CROP. Any ideas for getting my stuff to look the way it’s supposed to?
    Tom Wolsky replied 21 years, 5 months ago 6 Members · 6 Replies
  • Walter Biscardi
    April 7, 2005 at 9:37 am
    You need to look at your footage on an external monitor.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Tom Wolsky
    April 7, 2005 at 1:14 pm
    Make sure your DV sequence is in widescreen. If you’re seeing letterboxing it sounds as if the DV sequence is standard 4:3.
  • Jonathan White
    April 7, 2005 at 3:51 pm
    I can’t answer your question but maybe you can help me!
    I’m considering the HDV camera for broadcast work that I would normally do in anamorphic DV. Do you notice much difference in picture quality when downconverted??
    (I think your answer lies in your sequence settings as others have explained).
    Johnny
  • Will Salley
    April 8, 2005 at 5:03 am
    Make sure “Anamoprhic 16×9” is checked on in the sequence settings. Your setting of “squeezed” is the correct one.
    System A Info G5/Dual 2 – 10.3.6 – QT v6.5.2 – 4GB ram – Radeon 9800Pro – Lacie FW800 L1 RAID via Lacie PCI card and internal – Decklink Extreme – Wacom 6×8 System B is identical except: 2GB ram – Decklink SP – Radeon 9600 – Pro Tools
  • Vladimir Lozinski
    April 11, 2005 at 6:55 am
    I have a further question rather than an answer re this subject.
    I have been shooting with Z1 in DVCAM mode no problems. Edits fine in FCP.
    When I burn a DVD, it looks stretched. i.e. anamorphic.
    I have tried making my quicktime movie in PALDV 48K and PALDV 48K anamorphic.
    Still comes out the same.
    I am using Toast 6 for burning DVD.
    Any suggestions?
    Vladimir Lozinski.
  • Tom Wolsky
    April 11, 2005 at 1:35 pm
    Hi Vlad,
    Is Toast doing the compression or are you using something else? I’m assuming the material is 4:3 to start and it sounds like whatever is compressing it thinks it’s 16:9.
    All the best,
    Tom
