Activity Forums Media 100 HVR-M10E mystery
  • HVR-M10E mystery
    Posted by Kieran Matthew on August 7, 2007 at 10:13 am
    Hi All,
    I’m working with HDV at the moment and that requires me to rent an HVR-M10E deck.
    Despite it being set for PAL, 50i, downconvert, output DV over the iLink, media 100 insists that the machine is outputting “DV/DVCPro-NTSC”.
    This of course stops it running as the video is incompatible (its PAL) and so is the TC.
    At first I thought the deck was faulty and ordered a replacement. This arrived, but in the mean time the first deck started working.
    Now I’ve tested the replacement and it is doing the same – my media 100 insists it is NTSC although it isn’t.
    I’m not sure if this is a deck or a system issue – anyone have any ideas or indeed ever experienced anything like this ?
    K
    Kieran Matthew replied 19 years, 1 month ago 3 Members · 4 Replies
  • Michael Slowe
    August 7, 2007 at 4:18 pm
    I had exactly the same problem! I normally convert my HDV from the M10 deck through Convergent Design’s HD-Connect to uncompressed HD for acquiring into Media 100 (11.5.1) because that is the best away to avoid GOP compression problems. However when I only need an SD timeline I tried to digitize a downscaled signal from the deck into Media 100. I got the same message as you. I finally abandoned this route and transferred the downscale to my DSR 20 deck and then digitized from that to Media 100, no problem.
  • Kieran Matthew
    August 7, 2007 at 4:32 pm
    Hi Michael,
    Aha! So I’m not going mad! But what still remains a mystery is why the first hire two weeks ago went without a hitch, and this one worked, but only after fighting with it for hours.
    I reckon there’s a bug in the routine when Media 100 interogates the deck over the firewire to get its ID (for that drop down menu in the preferences). It might be a “luck of the draw” situation as to whether it correctly guesses the standard.
    I’m guessing this is a PAL issue, as I doubt it causes a problem if the material is actually NTSC
    Thanks for the heads-up and for the workaround!
    K
  • Chris Stevens
    August 8, 2007 at 8:32 am
    I have same problem (HVR M15E). But despite M100 saying it’s in NTSC mode, when I digitise the clips are in PAL!
    G5 dual 2.7, OS10.4.10, 4G RAM
    Media100 HD V11.6 & Producer, AE 7
    3.6 terra RAID
  • Kieran Matthew
    August 9, 2007 at 9:25 pm
    Hi Sheeplove,
    [Sheeplove] “But despite M100 saying it’s in NTSC mode, when I digitise the clips are in PAL!”
    That’s interesting – mine wouldn’t take footage in at all. The track buttons remained yellow the whole time.
    K
