Activity Forums Apple Final Cut Pro Legacy HV30 hdv 1080 60i Capture Problem
  • HV30 hdv 1080 60i Capture Problem
    Posted by Adrian Salinas on January 10, 2010 at 4:03 am
    Hi Everybody, So my problem is the following:
    I am Trying to capture hdv footage I shot on my hv30 with fcp, I have done this hundreds of times with no problems, but now I can get fcp to recognize the hv30 a a deck, I am using the hdv 1080 60i
    and the apple intermediate codec, I am using snow leopard and fcp7.
    the odd thing is that on my laptop I can capture this footage on SD with the dv easy set up.
    but if I change it to hdv it does not recognize the deck.
    the footage is shoot on hdv not on dv.
    I have a 8 core mac pro and a 13″ mpb
    any ideas will be greatly appreciated.
    thanks you
    A
    Adrian Salinas replied 16 years, 7 months ago 3 Members · 3 Replies
  • Zane Barker
    January 10, 2010 at 4:30 pm
    Sounds like your camera is probably downconverting the video to SD and therefor only sending out a SD signal.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Joe Paolo
    January 10, 2010 at 7:30 pm
    Had this issue with my HV20 when I was capturing a mix of DV and HDV. I had to shut down FCP. Play the tape for a few seconds to let the deck switch to the appropriate setting. Then restart FCP and select the appropriate settiings. I was capturing native DV and HDV though.
    joe
    editmojo.com
  • Adrian Salinas
    January 11, 2010 at 2:17 am
    Thanks guys!! I found out I had the camera set to output only DV, a menu setting , now its all working, could not have done it without your help, thank you
