Activity Forums Blackmagic Design HV30 and Blackmagic HDMI Capture
  • HV30 and Blackmagic HDMI Capture
    Posted by Stephen Rogers on September 15, 2008 at 2:49 pm
    Does anyone have experience using an canon HV30 with a blackmagic card? I read on another broad that you could capture better quality video using the hdmi input. But does this card also help with playback?
    Stephen
    Mike Browning replied 17 years, 11 months ago 3 Members · 2 Replies
  • Mark Keck
    September 15, 2008 at 3:12 pm
    I’ve been using the Intensity for capture with an HV20 for several months now with no issues. Should be the same for the HV30. You’ll only get a bump in quality if you’re capturing live… that is, not just playing back a tape. If you’re just ingesting tapes via HDMI there is no benefit over firewire as quality will be the same but you’ll lose the metadata.
    As for monitoring out of you time line or playback, I’m just starting to sort this all out and I’m having a problem with it. See my post a few down from yours. It’s working for me, but only if I have my camera plugged into the input HDMI and turned on.
    For live capture it’s been great and I’m sure once I get this other issue worked out it will be a real work horse for me.
    Mark
  • Mike Browning
    September 17, 2008 at 3:28 pm
    I have previously used an HV20 via FireWire for my XH-A1 tapes – so I’m considering HDMI capture with the Decklink, but I’ve heard that it doesn’t preserve timecode? What’s the deal and is there a work around?
    Mike Browning
    Vision Quest Media
