Activity Forums Canon Cameras HV20 why 1440×1080?
  • HV20 why 1440×1080?
    Posted by Brad Mirman on March 13, 2010 at 1:55 am
    I am doing a project where I am using a Canon T2i as A cam and HV20 as B Cam. After removing pulldown from the HV20 I am left with 1440z1080 23.98 clip.
    I use FCP and My work-flow is to capture HV20 24p footage with DVHSCAP… covert M2T file with MPEGStream to MPEG and ProRes. I import MPEG into Compressor and use Apple ProRes for Progressive material High Quality. Frame control is on and deinterlace is set to Reverse Telecine. When I import into FCP I get a 1440×1080 resolution. Why not the 1920×1080? Or does the HV20 not shoot 1920×1080 in 24p?
    I am concerned because my 24p footage from the canon is importing at 1920×1080
    Robert Dix replied 16 years, 6 months ago 4 Members · 4 Replies
  • William Busby
    March 13, 2010 at 7:10 pm
    I’m not a Mac user, so can’t help you there. But 1440×1080 is HDV2 spec. The HV20 records in 1920×1080), but is sampled down to 1440*1080 when it records to tape. Then it’s sampled up to 1920×1080 when played back. Must be an issue in your capture settings somewhere.
  • Brian Louis
    March 14, 2010 at 2:52 pm
    [William Busby] “Then it’s sampled up to 1920×1080”
    When its played back from tape and transfered to a computer via firewire or HDMI its still 1440×1080 anamorphic, the only way you can get full 1920/1080 is to use the HV20 as a live camera head and capture via hdmi, or capture component, if you capture live cam via firewire you get 1440×1080
  • Robert Dix
    March 18, 2010 at 11:25 pm
    I have not detected any difference in quality , in fact combining Canon EOS 5D Mark II 1920×1080 p clips in Premiere Pro and Export to Tape looks identical.
  • Robert Dix
    March 19, 2010 at 12:28 am
    Incidentally we have used the Canon Hv 20 for three years for broadcast quality high definition clips, the 5D Mark II mov clips at 1920 x 1080 are great but, there is little between the two.Even Canon says you can use this HV20 as a vtr for clips from their XL H1, XH G1 or XHA 1(both 50i and25 F mode)Quote Canon manual 0067W579 Pub DIE-281 0207N10-3, we Export to Tape only with minor copies dowgraded to DVD but, even that using the Adobe Media Encoder Cineform avi looks more than acceptable.
