Activity Forums Adobe After Effects hurricane of particles
  • hurricane of particles
    Posted by Stef Prein on January 5, 2008 at 4:27 pm
    Is there a possibility to create some sort of hurricane of particles? The particles should look like a hurricane of sheets, like in the HP ad with Paul Teutul Sr. of Orange County Choppers (example). In my case the particles should whiffle around a live-action person.
    I tried Particular Playground and Trapcode Particular. But I didn’t get the hurricane effect. Is this possible in AE, or should I use Motion or a different plugin?
    Thanks in advance!!
    Stuffy
    student Image and Media Technology
    Utrecht School of the Arts
    The Netherlands
    Itamar Kool replied 18 years, 8 months ago 4 Members · 4 Replies
  • Austen Mathieson
    January 5, 2008 at 6:31 pm
    I’m 70% positive you can use Trapcode Particular to achieve this kind of effect, I did get it with smoke so it must be possible to change the source particle to whatever is required like the papers etc.
    Austen Mathieson
    Austentatious Productions
  • Mike Clasby
    January 5, 2008 at 7:49 pm
    I don’t have Particular but you should be able to do it there.
    You can get a hurricane like vortex with CC Particle Systems II, standard on AE, with Physics>Animation>Vertex, and Particle>Particle Type>Textured Squares, on a comp sized custom particle layer, say a typed paper… you need to tweak birth size to see the whole layer when they are particle.
    Here is an expression driven tut from Colin that puts layers into a tornado (the second part):
    https://www.colinbraley.com/tornado_expressions_tutorial.html
  • Stef Prein
    January 6, 2008 at 12:13 pm
    Thanks guys! I never used cc particle system II, I didn’t even know that it excisted… I’m going to try it. Thanks a lot!
    Stuffy
    The Netherlands
  • Itamar Kool
    January 6, 2008 at 1:04 pm
    If all this doesn’t work the way you want it, you could take a look at the new plug in from Trapcode called ‘Form’.
    Succes ermee
    Kool En De Anderen
    MAC Pro 8 core/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
    http://www.koolendeanderen.nl
