Humbly requesting 3 minutes from a maestro
Hi. I am fairly fluid on a basic level with FCP(6). Using macbook Pro and an external scratch.
I’m beating out a script and have been abusing the built-in camera with QT for some video ‘notes.’ Recently I dumped them into FCP so I could take advantage of the timeline, etc. At this point the clips aren’t for anything other than reference, but I’m referencing them quite often. And they continue to grow.
I’m recording them under Best H.264. I understand that is not a codec for editing in FCP. I’ve compressed them to DV before, but there was some funny business (probably didn’t have all the settings right). Then I found I could just import the .mov files and drag them into the timeline, render them, and they’re fine. Aspect ratio solid, audio in sync. Happy. Only (and this is true with DV transfer too), as you all well know, the file sizes are now about, umm, 100 times larger than they were before rendering.
I’m wondering if there’s a solution for getting small somewhere. FCP referencing the QTs without making monster files?, importing smaller transcoded FCP-friendly files?, etc. Eventually I may do something with them, and so am belatedly considering recording future notes uncompressed. The files then seem about the same size as they are after a DV transcode, but with the plus that I don’t have to render them to scrub around in FCP. So maybe I’ll just work that way and use the dwindling GBs to curb my note taking?
But if anyone has something elegant to offer, I’m appreciatively all ears.
ML
