Activity › Forums › Adobe After Effects › Humble Monster, MacPro Upgrade
  • Humble Monster, MacPro Upgrade
    Posted by Ervin Tia on May 22, 2013 at 8:27 am
    Hello!
    I’m just wondering what’s the most logical way of improving my current machine. We originally bought it for AvidMediaComposer but recently, we are including more AfterEffects tasks. We realize we needed to improve the performance of the current process.
    What would be your recommendation?
    Here’s my current MacPro spec:
    Model Name: Mac Pro
    Model Identifier: MacPro5,1
    Processor Name: Quad-Core Intel Xeon
    Processor Speed: 2.4 GHz
    Number Of Processors: 2
    Total Number Of Cores: 8
    Memory: 10 GB
    Display: ATI Radeon HD 5770
    Ervz | Video Productions | WMC-AP, Philippines
    https://vimeo.com/ervzman/videos
    Ervin Tia replied 13 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Walter Soyka
    May 22, 2013 at 1:39 pm
    More RAM. This will allow you to exploit multiprocessing, a feature which basically launches multiple copies of the After Effects renderer in order to render multiple frames at the same time on separate CPU cores.
    I generally recommend 4 GB per core, so your 8-core machine should have 32 GB.
    For more specific suggestions, please describe what sort of work you’re doing and where you’re running into bottlenecks.
    Walter Soyka
  • Ervin Tia
    May 22, 2013 at 5:00 pm
    Thank you Walter.
    We mainly work with SD,HD videos, nothing fancy just DSLR and Camcorder footages. We’ve just started incorporating simple motion graphics and titles on it.
    The challenges I’m encountering is I guess really basic muscle power, as you mentioned. Rendering speed and preview are the main ones right now.
    More power!
    Here’s our recent work: https://vimeo.com/apnazarene
  • Ridley Walker
    May 22, 2013 at 8:58 pm
    In addition to more RAM, if you’re using CS6 you could add an SSD to serve as a Disk Cache. From my perspective, the Global Performance Cache and Persistent Disk Cache were the killer features in the CS6 release.
    https://www.video2brain.com/en/lessons/global-performance-cache-and-persistent-disk-cache
  • Ervin Tia
    May 23, 2013 at 3:05 am
    Great!
    What about the graphics card? I noticed that my current card is not listed in Adobe. Is this a big deal?
    Also, please educate me on shopping/specs. Should I always go with a NVIDIA brand? What about others that carries the same GeForce (example) model name?
  • Ridley Walker
    May 23, 2013 at 4:36 am
    If you’re asking about After Effects, the graphics card only comes into play when it comes to the new Ray Traced Renderer.
    If you intend to use those features then an nVidia card with CUDA will benefit your workflow, otherwise you won’t see any difference.
  • Stefan Hinze
    May 24, 2013 at 5:24 am
    Hey,
    More RAM, a SSD, and CUDA.
    My Mac is a 3,1 from 2008.
    8 core
    24 GB
    SSD for the System
    GTX 285 – CUDA (in Premiere Mercury-Engine)
    I render out a 10min clip from 1080 to 720 in about 6min…
    PP hase some CUDA/Mercury supportet FX, so in most cases, even CC dosn´t slows it down!
    Hope this helps!
  • Ervin Tia
    May 24, 2013 at 7:45 am
    Awesome! Thanks for the ideas.
    Currently, our workflow goes like: AfterEffects for graphics – AvidMC for final edit, music mix, and finish.
    For the Avid part, we’re pretty good with the system and performance. But then of course any upgrade will be beneficial.
