Activity Forums Adobe After Effects Human Spine Animation in AE
  • Human Spine Animation in AE
    Posted by Ben Lewis on May 27, 2016 at 4:14 pm
    Hi, I’ve been asked about a job which would involve animating a graphic of a human spine and wondered if anyone could suggest a plugin that might help with the rigging/physics as it should move naturally to demonstrate how to correctly lift objects?
    Basically an actor would act out the moves then on the right of the screen I want to animate the spine so it mimics what the actor is doing.
    This is a great example of what I am trying to achieve but created in 3D. https://www.youtube.com/watch?v=U1dnJ8pu-do
    Any help or tutorials would be greatly appreciated.
    Kalleheikki Kannisto replied 10 years, 2 months ago 3 Members · 2 Replies
  • Kevin Camp
    May 28, 2016 at 3:02 pm
    if your not going for the realism in the example, and would settle for a simple bending of a spine layer, cc bend it can very easily bend a layer which could mimic the behavior of a spine.
    you can easily see if it will work for you, just find a picture of a spine and add cc bend it. you’ll have two anchor points to effect the bend, the ‘start’ is the base, or fixed point, and the ‘end’ is point that will effect the bend. place the start point at a point you want the bend to start (like the base of the spine), then manipulate the end point to create the bending.
    it is a simple distortion effect, and the you will get distortion in the vertebrae, but if the bending isn’t too extreme it may work for what you are doing.
    to do it more correctly would involve linking separate vertebrae layers with expressions so when you move one vertebra, the others move and rotate independently as needed to more accurately follow the adjusted vertebra. it’s possible, but a little complicated to work out math and expressions involved.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Kalleheikki Kannisto
    May 28, 2016 at 4:10 pm
    If you’re not rotating the spine in 3D, the puppet pin tool would probably work to bend a static spine image in a natural fashion. You can control the stiffness of different parts with the starch tool. The bones will distort slightly, but it might not be noticeable.
