Activity › Forums › Adobe Audition › Hum on sound outside Adobe Audition
  • Hum on sound outside Adobe Audition
    Posted by Simon Sanders on March 8, 2013 at 3:57 pm
    When I bring my .wav recording into Audition it sounds fine. However, when I listen to it the original file it appears to have a hum. The hum comes back upon export. Where is it coming from and how can I get rid of it?
    Simon Sanders replied 13 years, 6 months ago 3 Members · 5 Replies
  • Angelo Lorenzo
    March 8, 2013 at 10:15 pm
    What are you using to listen to it outside of Audition?
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Simon Sanders
    March 9, 2013 at 10:26 am
    Hi Angelo,
    I use a variety of systems including Windows Media Player, AVS and when posted to the internet Audioboo.
    Thanks for your interest
    Simon
  • Joseph W. bourke
    March 9, 2013 at 3:26 pm
    Angelo seems on the right track – check your playback system to make sure that the gain settings for other sources are either off or turned way down. It may not be in the track at all. Take a look in the track waveform in Audition in “silent” areas. Is there a waveform still there? If so, it’s in your track, and you’ll need to sample and remove the Noise Floor to get rid of it.
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Angelo Lorenzo
    March 9, 2013 at 7:25 pm
    Here is what I want you to do:
    Look at your original file in Audition in the spectral mode. Do you see a line going across the file in the higher frequencies or a heavy wash of energy in the higher frequencies? This is what hum/buzz would look like.
    Look at your exported file in spectral analysis, does it have any hum or buzz in this view?
    What is the file in terms of sampling? 48kHz 24bit? Lets say your sound card is set to play back 44.1kHz natively. Audition will process playback to match your sound card. These other audio programs probably aren’t so they’re relying on the resampling of the sound card. You may be listening to artifacts created by your sound card.
    Angelo Lorenzo
  • Simon Sanders
    March 10, 2013 at 10:23 am
    Hi Angelo and Joe,
    Thanks for your thoughts I have looked at the files in spectral mode but can see noting that would cause a problem. I think that you could be right about sound card being the issue. However, since I am working on a portable I do not suppose that I can do much about that.
