Activity Forums Adobe Premiere Pro Huge timing bug/error/problem…help?
  • Huge timing bug/error/problem…help?
    Posted by David May on May 12, 2008 at 3:15 pm
    ARGH. for reasons unknown to me, a large number of my shots have lost their timing. All the footage on my time line from 3 imported video files has gone back by a few seconds. Every clip on the timeline with that footage in it is still the same length, but of a previous bit of footage. So where things were all timed to perfection, its gone straight to hell. I have 8 sections of footage and from what i can tell 2, 8, and 6 are the ones that have been affected.
    Before this happened i was getting a media offline error for some footage (probably the same ones come to think of it), but after running the updater, that was fixed and i had normal footage back. or so i thought.
    Sorry for the impolite asking here everyone, but if i cant fix this, its going to be a cataclysmic failure for my major work.
    Perry Cheng replied 18 years, 4 months ago 2 Members · 6 Replies
  • Perry Cheng
    May 12, 2008 at 4:55 pm
    What’s the format of your video?
    Perry
  • David May
    May 12, 2008 at 11:29 pm
    the video is HD mpeg format, Ive got a sony HD camera so i just imported straight in. I had numerous saves in many different locations, but i think its the “encoded files” folder is that the change has been applied to, because all of the save files do exactly the same thing with those 3 clips.
    The only solution i can think of is use one of the low res exports i made 2 days ago and match the shots back up.
    thoughts?
  • Perry Cheng
    May 13, 2008 at 1:44 am
    What’s you computer made up?
    Perry
  • David May
    May 13, 2008 at 3:57 am
    2.4ghz quad core, 4gb ddr2 ram, gforce 7950gt, 200gb sata + 500gb sata. why? any ideas?
  • David May
    May 13, 2008 at 6:32 am
    Well ive put the shots back in their original places, took about 3 hours but the main thing is its fixed. I put a low quality export i had made previously on the timeline and matched the shots up to it, just for future reference if anyone else finds the same problem. thanks for your help.
  • Perry Cheng
    May 15, 2008 at 3:11 am
    My initial thinking was that your system is not able to keep up with the high quality rendering. Perhaps your files resides on an external SATA HDD? Or you might have a bottle-neck somewhere. Well, the good news is, you figured a way around.
    Perry
