Activity Forums Storage & Archiving Huge PDFs from Bru-PE
  • Huge PDFs from Bru-PE
    Posted by Neil Sadwelkar on April 13, 2017 at 2:23 pm
    When one does a backup of about 2 TB of Alexa shoot files to LTO with Bru, and makes a PDF of the contents at the end of the backup, one ends up with a PDF the runs into thousands of pages, since Bru lists every single file. This makes it impossible to make a printout.
    Since Alexa shoots to file sequences, every frame is a file. 1440 files per minute (per 10 GB) so in 2 TB one would have some hundreds of millions of files each faithfully listed in the Bru PDF.
    Is there some way to present file sequences as a single entry?
    For instance, an Arriraw file sequence that runs from
    A004C001_170321_R56H.1309313.ari
    A004C001_170321_R56H.1309314.ari
    A004C001_170321_R56H.1328163.ari
    A004C001_170321_R56H.1328164.ari
    A004C001_170321_R56H.1328165.ari
    has 18853 separate entries in the Bru PDF
    But, If its listed like how DaVinci Resolve lists the above example as one entry, like
    A004C001_170321_R56H.[1309313-1328165].ari
    it could potentially bring down the size of the PDF to manageable (even printable) levels.
    And make it easier to browse through looking for a particular clip.
    Red camera or Sony files are no problem as one clip is one file, so PDFs of those camera backups are compact.
    With LTO-7 doing 5+ TB this is an even bigger problem.
    Any fixes?
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
    Neil Sadwelkar replied 9 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
