Activity › Forums › Adobe After Effects › Huge heavy file with proxy
  • Huge heavy file with proxy
    Posted by Luca Bej on January 17, 2018 at 12:48 am
    I’m testing a proxy in a test comp but when I export and I choose to use proxies my output file is 1,5GB, if I don’t use them, my file is 600mb instead…
    Is that correct? Both files should be the same!
    Anyway….
    I think that could happens as my proxy file has a low resolution and when AE try to render a low-res file making it bigger, every frame has more colors informations due to blurredness of the smaller movie/proxy that is now stretched and made bigger… Am I right?
    Tero Ahlfors replied 8 years, 8 months ago 2 Members · 1 Reply
  • Tero Ahlfors
    January 17, 2018 at 7:01 am
    [Luca Bej] “Is that correct? Both files should be the same!”
    You didn’t say anything about your source formats, composition settings or your export settings so it’s impossible to say.
