Activity › Forums › Apple Final Cut Pro › Huge Folder size discrepancy between 10.1 Managed and 10.0.9
  • Huge Folder size discrepancy between 10.1 Managed and 10.0.9
    Posted by Shawn Convey on January 5, 2015 at 2:41 am
    I sure do Hope that someone can help me out with this.
    I don’t want to make any mistakes that would result in Data loss.
    I have all my media for a large project I am working on on a Drobo 5D.
    The Drobo has a total Max usable space of 16TB. (5 Drives each 4TB in size)
    When FCPX 10.1 came out I upgraded and “saved” my old library. (Just in case)
    Once the “upgrade” was complete there were two different directories on my DROBO there was:
    “DROBO Old Final Cut Projects and Events” (which has a “normal” folder structure) &
    “DROBO Final Cut Projects and Events” (which had the “contained / managed structure)
    Shortly after I “upgraded” something happened and all my subtitles (all of the footage was subtitled… all 300 hrs) disappeared…
    After about 3 hrs of freaking out I quickly discovered that the subs and all my old project files were still ok in the old (just in case) directory and all I needed to do to keep working was go back to use 10.0.9 which is what I have been doing.
    However Now I have very little space on my DROBO and I want to get rid of the “newer” and unused “DROBO Final Cut Projects and Events” folder (which now shows up as a normal folder / directory as I no longer have 10.1 installed)
    And here comes the QUESTION:
    The numbers don’t add up…. the new Folder (the one I want to DELETE for 10.1) claims a size of 8.06TB (on “10.1 FCP P&E”)
    and the old folder that I want to SAVE claims a Size of 10.79TB (on “old FCP P&E”).
    In addition to those folders I have an additional 3.5TB of other files outside of those directories…
    OK so it doesn’t take a rocket scientist to see that the “used” space on my Drobo according to my finder is 22.35TB which is already impossibly large as I simply do not have that space on the drive… So when I look into the new directory (the one I want to delete) all the files appear to be “real” and not aliases which was the first thing I thought may be the issue (something funny where it was counting the file twice…)
    Anyway I just really want to DELETE that “new 10.1” directory however not at the cost of messing up my perfectly good 10.0.9 workflow.
    Please advise.
    thanks!
    Final Cut Pro X, OS X Mountain Lion (10.8.5)
    terraform
    Noah Kadner replied 11 years, 8 months ago 2 Members · 2 Replies
