Activity › Forums › Adobe After Effects Expressions › hue/saturation change
Posted by Sean Kimber on September 3, 2013 at 3:14 pmHi,
I’m looking to be able to control the hue and saturation of a series of colors based on a single color picker. In this case, I will be using a 4-color gradient for a background, and I’d like someone to be able to choose a color in the control layer and have four unique colors appear in the gradient, but have the hue based on the original picked color. Is there a way to accomplish this?
Dan Ebberts replied 11 years, 7 months ago 7 Members · 10 Replies -
Mitch Mann
September 4, 2013 at 3:00 pmSeems like you’d be able to pull the color array out into individual R, G and B values, then have your other colors each be a certain offset on R, G and B from the original, and put it back together again.
Darby Edelen
September 5, 2013 at 6:11 amThere’s also the rgbToHsl() and hslToRgb() functions to help. Get the hue of the color chosen in the colour picker then apply it to the colours of the 4 color gradient.
You could also drive a HSL effect applied after the 4 color gradient with these functions (but that effect is not 32bpc compatible).
If you don’t mind splitting the operation into 2 layers and using the Fill effect (or maybe just using the Solid Composite effect) with the Hue blend mode that’d be an easy way to go as well.
Darby Edelen
Ayas Hassan
April 23, 2014 at 1:25 pmHi Darby,
Can you please write me the expression that can do this?
Basically i have two layers. Fill color used in the second layers has to be a bit darker than the fill used in the first layer. ie, I want to control only the saturation of the second layer’s colour.
Thanks in Advance
Ayas Hassan
Motion Designer // 3D Animator
http://www.aeyaz.com
Dubai – UAE -
Xavier Gomez
April 23, 2014 at 1:58 pmHi Ayas,
darkness is not controlled by saturation, but by the lightness (3rd parameter in HSL). Since arrays are indexed from 0, that’s entry 2:
lightness = 25; // pourcenthsl = rgbToHsl(thisComp.layer("first").effect("Fill").color.value);
hsl[2] = lightness/100;
hslToRgb(hsl);
If you want to set a lightness offset that will auto update when you change the fill in the first layer:
lightnessOffset = -5; //hsl = rgbToHsl(thisComp.layer("first").effect("Fill").color.value);
hsl[2] = Math.max(0.0, Math.min(hsl[2]+lightnessOffset/100, 1.0));
hslToRgb(hsl);
Xavier -
Ayas Hassan
April 24, 2014 at 10:18 amPerfect. Thanks You.
When i said darkness, what i actually meant was a bit saturated colour. I just need a slight variation int the first colour. May be i just used the wrong word 🙂
Ayas Hassan
Dubai – UAE -
Tim Hildebrandt
February 8, 2015 at 7:59 pmHi there,
(example)
Two solids. Left one has the original color. The right one should always have the same hue, but the saturation should be at 45% and the lightness at 70% of the Original value.With this kind of expression it works fine for the lightness:
inRGB = //relating Color Path;
inHSL = rgbToHsl(inRGB);newLight = inHSL[2] * 0.7;
newHSL = [inHSL[0], newSat, newLight, inHSL[3]];
hslToRgb(newHSL);But if I try the same for the saturation, like here
newSat = inHSL[1] *0.45;
hslToRgb(newHSL);
The hole color is changing. The lightness is not at its expected value, the hue changed a bit and the saturation is not working as well.
So. What’s the mistake here?
Thank you for help!
Dan Ebberts
February 8, 2015 at 8:45 pmYour expression works as expected for me. I’m not sure why it doesn’t work for you, unless maybe you’re using an unusual color space or something.
Dan
Tim Hildebrandt
February 8, 2015 at 9:03 pmI tested it again and I will write down the expected and the happened results:
Original color settings from the square I have (for testing):
H=120°
S=100%
B=100%
ecpected result
H=120°
S=45%
B=70%
The final result looks like this:
H=120°
S=62%
B=51%
Where is my mistake? Where did you apply the expression on?
Greets
Edit: Here’s a pic of how it looks
Dan Ebberts
February 8, 2015 at 9:58 pmI think it may be an HSL vs HSB thing. For your initial color, I get an HSL of [.3333333, 1, 0.5, 1] which results in [.33333333, 0.45, 0.35, 1] after the multiplications.
Dan
