Activity › Forums › Panasonic Cameras › HPX500 SD output vs. KiPro downconvert
  • HPX500 SD output vs. KiPro downconvert
    Posted by Craig Mikhitarian on March 13, 2013 at 7:48 pm
    We’re shooting with HPX500 and client wants us to record 4:3 Standard Def ProRes files onto a KiPro via SDI. (The P2 recordings won’t be used.)
    So, we could either shoot and send a 720 HD signal to the KiPro and have KiPro downconvert to SD with center-crop, or, set-up the camera to shoot SD and send the SD signal to the KiPro.
    Any ideas on which would produce a better result?
    Also, is timecode embedded on the SDI signal from the camera? We’re shooting with 2 cameras that would have identical TC and, of course, want the KiPro files to record the same code.
    Craig
    Craig Mikhitarian
    ACM Productions, Ltd.
    Craig Mikhitarian replied 13 years, 6 months ago 2 Members · 2 Replies
  • Steve Eisen
    March 14, 2013 at 4:25 am
    I would go HD-SDI out of the HPX-500 and set the KiPro SDI to Downconvert. Timecode is embedded in the SDI signal.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Craig Mikhitarian
    March 15, 2013 at 2:56 pm
    Thank you for the response, Steve.
    Craig Mikhitarian
