Activity › Forums › Panasonic Cameras › HPX500 Output Question – ASAP Kinda Thing
  • HPX500 Output Question – ASAP Kinda Thing
    Posted by Peter Tours on June 9, 2012 at 1:19 pm
    Is it possible the analog component output of the camera, which we use for monitoring, can be different from the image being recorded on the P2 card?
    If so, is there an adjustment? I am assuming the monitor is properly calibrated, but it isn’t here yet. If it’s not I know that’s prbly the issue. If the monitor is properly calibrated, back to having only the analog component output for measurement and can it be trusted?
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Convergence ECS1B 1977-1979
    Sony BVE 500 1979 – 1984
    Datatron Vanguard 1984 – 1993
    GVG VPE141 1993 – 1998
    Media 100 1995 – 2006
    Final Cut Pro 2005 to infinity and beyond!
    Chris Tompkins replied 14 years, 3 months ago 2 Members · 1 Reply
  • Chris Tompkins
    June 10, 2012 at 3:24 pm
    It only outputs what your camera settings are and what you are recording.
    The only different option is to “downconvert”
    You can be shooting HD and video out a downconverted SD 480i signal.
    Chris Tompkins
    Video Atlanta LLC
