Activity › Forums › Panasonic Cameras › HPX370 USB host mode?
  • HPX370 USB host mode?
    Posted by Philip Fass on December 31, 2011 at 4:12 pm
    Using the HPX370. Toward the end of the manual, there are various things you can do with an external drive, like format the drive to “type S”.
    Here’s a typical set of instructions.
    1. Switch to USB Host mode.
    2. Connect HDD.
    3. Press THUMBNAIL button to open thumbnail screen.
    4. Press THUMBNAIL button and select HDD – Explore in the thumbnail menu.
    5. Select OPERATION – FORMAT.
    My problem is step 4. The second press of the thumbnail button only toggles off the thumb screen. Is there something I’m missing here, to continue on to the menu? Thanks.
    Chris Tompkins replied 14 years, 8 months ago 2 Members · 1 Reply
  • Chris Tompkins
    January 2, 2012 at 10:02 pm
    It does say “Some Hard disc may not operate normally”
    Have you tried another drive?
    Chris Tompkins
    Video Atlanta LLC
