Activity Forums Panasonic Cameras HPX300 noise problem
  • HPX300 noise problem
    Posted by Shaunn Baker on July 13, 2010 at 1:05 am
    OK…so here’s my ignorant question.
    I don’t know if this was an issue immediately with the camera or not, and I know the camera has noise issues. But…
    I’ve recently noticed an AMAZING amount of noise that I don’t think i’ve seen before. Here’s the specs…
    Lens cap on.
    Any one of the presets except Cine-V
    Low gain. Either 0 or +6
    White balance at +5K
    Noise goes away with tungsten color temps.
    Noise goes away when I set gain to +12 (normal and expected noise at 12, but not the excessive stuff I’m seeing)
    I haven’t had enough time to play with all the stuff in the camera yet, but is this normal? Do higher color temps add noise? Should higher color temps add noise?
    I know there are ways to hack this, like taking down detail, crushing the blacks, etc. But is this normal for this camera, or do I need to send it back to Alex in NJ again.
    Thanks a million.
    Shaunn Baker replied 16 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
