Activity › Forums › Panasonic Cameras › HPX2000 Battery Settings
  • HPX2000 Battery Settings
    Posted by Matt Gerard on June 8, 2009 at 6:24 pm
    In setting up the HPX2000, what battery selection would best match the IDX Endura10s batteries? Seems the camera is giving a warning way before the battery is low.
    Any Ideas?
    Matt
    Its more fun to ride a slow motorcycle fast than a fast motorcycle slow…
    John Cummings replied 17 years, 3 months ago 3 Members · 4 Replies
  • Jeremy Garchow
    June 8, 2009 at 9:06 pm
    What do you have it set to now? Endura 9?
  • Matt Gerard
    June 8, 2009 at 9:14 pm
    Whatever the factory default is. (camera is in use at the moment, so I don’t know exactly) But I don’t see my batt in the list when I went to change it. But When the camera starts beeping, the indicator on the batt still says half full. If I let it go until the camera dies (did a test, not during a shoot!!) I get another 30-35 minuets operating time.
    Just not sure what the equivalent battery is in the menu options.
    Matt
  • Jeremy Garchow
    June 8, 2009 at 9:18 pm
    There’s three Endura settings in there. Try the one closest, if that doesn’t work, try another.
    Jeremy
  • John Cummings
    June 9, 2009 at 1:52 pm
    I had the opposite problem with my HDX. I wouldn’t get enough warning before the battery crapped out.
    While I’m not an expert, the best fix I found was to start with the factory setting for my battery…then over a period of uses, tweak the voltage setting for the warning. You can do that in the same menu as the presets. In your case, you would want to start by lowering the voltage setting until you hit the sweet spot with the warning.
    It will always be somewhat of a moving target. Obviously there’s a bunch of variables at play here: Each battery will age differently, environmental conditions like temperature will affect run times, and you may want to consider how much extra power you might be drawing due to any connected accessories like wirelesses.
    In the case of a file-based recording system like P2, I would always opt for an earlier warning.
    J Cummings
    Cameralogic/Chicago
    cameralogic.tv
    HDX-900/HDW-730S/DXC-D50
