Activity Forums Panasonic Cameras HPX2000 AVC-INTRA 100 Noise
  • HPX2000 AVC-INTRA 100 Noise
    Posted by Jeff Boyer on March 11, 2009 at 3:13 am
    We’re shooting with a HPX2000 with a Intra card installed. So far, rather we shoot 720P 60 or 1080i we get a fair amount of noise in low light areas of each scene. Of course, when we run a line direct to our Panasonic 17HD monitor, it looks great. It’s always the recorded/compressed image that has noise. I’ve been using a factory setting, Vivid setting, the film-1 setting, as well as a some other personal settings. Our DVCPROHD setting also has a fair amount of noise. I just sent the camera back to Panasonic and it checked out fine. Any ideas?
    Jim Wilcox replied 17 years, 6 months ago 4 Members · 6 Replies
  • Jan Crittenden livingston
    March 11, 2009 at 1:03 pm
    Do you have the Dynamic Range Stretch on? Some folks think this is something you leave on all the time and it is not. If the scene doesn’t need it, it should be turned off.
    Hope this helps,
    Jan
    Jan Crittenden Livingston
    Product Manager, HPX500, HVX200, DVX100
    Panasonic Broadcast & TV Systems
  • Jeremy Garchow
    March 11, 2009 at 3:27 pm
    Any chance you can post a few seconds of material?
  • Jeff Boyer
    March 14, 2009 at 7:06 am
    HiJan,
    My DRS is turned off. Thanks Jeff
  • Jeff Boyer
    March 14, 2009 at 7:14 am
    A tech from Panasonic thinks the issue may be that I’m using Pro Res HQ for importing the files and not 10 bit raw. I wasn’t sure how to import a 10 bit file unless I use our HD log program, which I don’t have in the field. Do you think this could be the problem? Do you know how to import 10bit into FCP 2? I uploaded some sample video as well. Sorry for my delay on getting back, I’m on-location shooting, (different system). Thanks in advance!
  • Jeremy Garchow
    March 17, 2009 at 5:30 pm
    Currently as of right now, the ONLY way to get 10bit material from AVC-Intra in to FCP is the Log and transfer method as it is the only process that will handle the bit depth properly.
    Quicktime can’t do it, and any other application that uses Quicktime can’t do it, like HD log. HG log does an 8 bit decode of the 10bit AVC-I material. Careful with that.
    It is not a problem to use log and transfer.
    Where’s the footage you uploaded?
    Jeremy
  • Jim Wilcox
    March 17, 2009 at 5:49 pm
    You mention you uploaded some sample files, but did not say where…
