Activity › Forums › Panasonic Cameras › HPX2000 and Lectro dual channel wireless receiver?
Posted by David Coleman on July 2, 2008 at 8:19 pmI see from Lectrosonics’ website (https://www.lectrosonics.com/hybrid/sr/sr.htm) that my new camera doesn’t support both channels from my new receiver. Until a December firmware upgrade, apparently. That would have been nice to hear from my dealer….Anybody have first-hand experience with this?
David Coleman replied 17 years, 4 months ago 3 Members · 17 Replies -
David Coleman
July 2, 2008 at 8:41 pmOk, mine hasn’t shippped yet so I can’t look and see, but my understanding is the 5p variant which you seem to describe is a somewhat different model with the TA5 jack on the top. Otherwise, where does the cable connect?
Jeremy Garchow
July 2, 2008 at 8:47 pmNevermind, you need the 5p. Yes your dealer should have told you or at least swap it out.
David Coleman
July 2, 2008 at 8:52 pmYes, but the page shows two different models, the SR and the SR/5p variant. Do you have either of these receivers? If so, does the 5p come with it, or is it an accessory as it appears? Maybe it is included and I’m not reading it right.
David Coleman
July 11, 2008 at 8:46 pmUpdate: I spoke with a news photog who uses both the 2000 camera and the aforementioned receiver. He informed me that the camera mixes the two channels it receives from the receiver. He reiterated that Panasonic has planned to release a fix for this in the December firmware upgrade.
DC
Jeremy Garchow
July 14, 2008 at 2:35 pmSo are you gong to stick with the one you have and HOPE that Panasonic releases the update on time?
Also, mixing channels, that’s not good.
David Coleman
July 14, 2008 at 2:44 pmI’m going to keep it in hopes that Panasonic delivers on the firmware update. The slot-in is the real attraction for me–not having an external receiver to get bumped around and cables to snag. I just wanted everyone else to know about this issue so they didn’t have to find out like I did: after ordering.
Jeremy Garchow
July 14, 2008 at 3:33 pmYeah, but if you get the other model, you can use the discreet output channels and then when the firmware update comes through, you can then use them internally. In the meantime, you won’t be stuck with one mixed channel.
Jeremy
