Activity › Forums › Panasonic Cameras › HPX2000 720p30 vs 1080p30 DVCPRO HD
  • HPX2000 720p30 vs 1080p30 DVCPRO HD
    Posted by Paul Anderegg on October 21, 2013 at 10:57 pm
    I have a DVCPRO HD only HPX2000, and I am curious if I shoot in 1080 30p mode, will I be able to achieve higher resolution than 720 30p mode if I convert down to 720p30 for the final file. I understand DVCPRO HD 720 is really 960×720, but 1080 comes out at 1280×1080, so I would be able to get full horizontal resolution right? I imagine there might be some issues with this though.
    Also, why doesn’t my DS GAIN function work in 30P mode, that sucks. 🙁
    Rainer Wirth replied 12 years, 11 months ago 2 Members · 1 Reply
  • Rainer Wirth
    October 29, 2013 at 3:26 pm
    Obviously the 1080p is better than the 720p. If you have to deliver 720p then I would shoot on 720p and keep it through the entire workflow. The DVCProHD files are nearly as good as real 1920×1080 pictures. The best results come with the intra codec. There is a extension card for the 2000, it’s worth buying.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
