Activity Forums Panasonic Cameras HPX170 Transferring Audio Nightmare!!!
  • HPX170 Transferring Audio Nightmare!!!
    Posted by Marcus Mcdougald on August 27, 2009 at 4:42 pm
    So I’m fairly new to the HPX170 and I’m having issues when trying to transfer my footage.
    The audio ends abruptly midway through the clip. I immediately thought frame rate problem,
    but when I checked the clips on the camera at DV100 720/60p and then adjusted my system, sequence, and A/V settings to DVCPRO HD 720/ 60p and re-transfered, the audio still cut out. Can anyone save me
    from the perils of my new technology nightmares?!
    Marcus A. McDougald
    “art is not what you see but what you
    make others see” – Edgar Degas
    John Fishback
    replied 17 years ago
    2 Members · 3 Replies
  • John Fishback
    August 28, 2009 at 9:44 pm
    Please describe your system and workflow. In particular, what drives are you using and how are they formatted?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Marcus Mcdougald
    August 29, 2009 at 1:45 am
    Thanks for your inquiry John. I am storing my footage on an external WD IBook formatted for mac.
    I’m transferring via FCP 6.0.6. Is the processor speed necessary? I’m not too sure without digging for it.
    Let me know if this helps.
    Thank you,
  • John Fishback
    August 29, 2009 at 5:11 pm
    Does the audio play to the end of the clip in the camera? Is this happening with just one clip – or all the clips?
    John
