Activity › Forums › Panasonic Cameras › HPX 300 Shooting LCD Monnitor
Posted by Jerry Vogt on January 19, 2012 at 10:15 pmAny advice would be appreciated. I’m shooting an over the shoulder training of how to use a software program on an LCD monitor with my HPX 300. I have adjusted the syncro-scan so that the rolling horizontal line disapears but when I’m in for tighter shots and completely focused I get this bright diagonal pattern. Also when panning on the screen I get white flair ups. Any ideas?
Jerry
Jerry Vogt replied 14 years, 8 months ago 4 Members · 11 Replies -
Jerry Vogt
January 20, 2012 at 12:56 amTom,
Just checked my settings, zebra was off but when I close my iris down to 5.6, I can completely focus to peak without getting that group of diagional lines. Now all I get is a moire like patten in brighter area’s of the screen when I pan.
I will change the background to a solid dark color and that should help.I realise that programs like Camtasia could do a better job but this is a short demo and don’t want to spend the $300.
Thanks.
Chris Tompkins
January 20, 2012 at 1:26 pmAre you viewing the footage proper after the shoot?
Chris Tompkins
Video Atlanta LLC -
Jerry Vogt
January 20, 2012 at 2:33 pmI’m viewing the image on my camera’s lcd screen, have not recorded anything yet. This morning I tried shooting a laptop and found that the iris needed to be opened more, and once again I see these flashes of light on the camera’s lcd screen with thin diagonal lines.
I checked that my lens mount was secure. I also tried to shoot from a slight angle but the problem is still there.
Chris Tompkins
January 20, 2012 at 2:35 pmYou need a high-end large field monitor connected via SDI OR
View footage in edit suite connected to a Video monitor to judge. Don’t judge what you see in the Cam LCD.Chris Tompkins
Video Atlanta LLC -
Jerry Vogt
January 20, 2012 at 3:37 pmI will record some footage and import into FCP later today. Will post results.
Tom Prigge
January 20, 2012 at 7:59 pmYou mentioned Camtasia being out of your budget for this project. They do have a trial download, I believe.
I use Camtasia quite a bit. Works great.
Jerry Vogt
January 20, 2012 at 10:05 pmI recorded the computer screen this afternoon, which is a Samsung Synk Master 26″. Recorded in DVCPRO-50 60i and imported into FCP. Same problems as I saw on the on camera lcd. So I went in and changed the peaking setting to -7 which should have nothing to do with the recording but it did seem a little better. Then tried AVC-Intra 720p and I can still see line patterns all over the place.
Thanks to everyone who has responded.
Michael Alberts
January 21, 2012 at 6:16 pmScreenFlow from Telestream is only $99. We use it for computer demos all the time. Works great with FCP for editing. Has l
Michael Alberts
Ambidextrous Productions, Inc.
http://www.ambidextrous.net -
Michael Alberts
January 21, 2012 at 6:18 pmScreenFlow from Telestream is only $99. Would that be in your budget? We use it for computer demos all the time. Works great with FCP for editing. Has lots of great features for zoom control and mark ups.
Michael Alberts
