Activity › Forums › Apple Final Cut Pro › hpx 170 p2 cam 720p 30pn
  • hpx 170 p2 cam 720p 30pn
    Posted by Craig Alan on March 14, 2014 at 11:36 am
    plays fine in cam but plays in slow motion in FC and out of sync with audio? 60p plays fine.
    1) is this a camera settings problem or a FC settings problem.
    2) Is there a way to capture the footage to resolve the problem?
    I’m also going to ask at the panasonic P2 forum since it might be a camera settings issue.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
    Craig Alan replied 12 years, 6 months ago 2 Members · 6 Replies
  • Jeremy Garchow
    March 14, 2014 at 1:41 pm
    Sounds like you shot 30p and not pn?
    Did you check the “remove pulldown” box in the import window?
  • Craig Alan
    March 14, 2014 at 3:57 pm
    Yeah you are correct. I wrote the post at home and thought I had it set for pn. 30P under recording setup on the 170.
    Remove pulldown is correct or not correct? I believe I had it checked. But I’ve tried it both ways and still getting slow mo.
    What settings would you recommend for the 170/FC import?
  • Jeremy Garchow
    March 14, 2014 at 4:26 pm
    I’m not sure if I’ve worked with this footage in X before, but I’d tell you what I would do.
    I would import with “remove pulldown” UNchecked and edit in either a 59.94 or 29.97 timeline.
    FCPX should be able to correctly remove the pulldown in a 29.97 sequence (at least FCP7 could).
    Jeremy
  • Craig Alan
    March 14, 2014 at 6:00 pm
    Maybe that’s possible but in X I import footage and FC just dealS with it. In the inspector it says its
    960×720 29.97p DVCPROHD 720p60/30/24 linear PCM
    In 7 I used to choose what I wanted In X it ewirther imports fine or it is “optimized” upon import.
  • Jeremy Garchow
    March 14, 2014 at 6:01 pm
    [Craig Alan] “Maybe that’s possible but in X I import footage and FC just dealS with it. I”
    That’s fine as long as it’s not slow motion.
    If it does come in conformed, then import without removing pulldown.
    Jeremy
  • Craig Alan
    March 14, 2014 at 6:33 pm
    I tried it wout pull down. I’ll try again. Thanks for your help. Never had a problem with P2 media before now.
