Activity Forums Blackmagic Design HP Z400 w/Quadro 2000, What Drivers Work ?
  • HP Z400 w/Quadro 2000, What Drivers Work ?
    Posted by Jeffrey Morrison on January 23, 2012 at 4:15 am
    I have been fighting with a z400 system with a Quadro 2000 card.
    at first I had frame drops at 1080i 60 frames, screen would flash randomly.
    then i moved the cards around contrary to BMD insructions placing the ultrascope card directly under the video card.
    the flashing stopped nut other anomilies remain.
    for one, the Waveform is not accurate, I know this becasue i have another pocket ultrascope that shows the true signal,
    also, in the video representation of the waveform when displaying bars, you see clear extra lines as if the pen is not lifting in a plotter.
    the other problem is that when i am in the two window mode, the drop down menu doesnt operate and the screen is frozen.
    any sugesstions for this one would be helful. thank you
    Jeffrey Morrison
    Jeffrey Morrison replied 14 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
