Activity Forums VEGAS Pro HP Workstation
  • HP Workstation
    Posted by Roger Bansemer on October 11, 2016 at 10:51 am
    I’m filming using some 4K now and am anxious to upgrade my system to better handle it.
    Any model recommendations for an HP workstation?
    Roger
    Roger Bansemer – PaintingAndTravel.com
    Peter Ermens replied 9 years, 11 months ago 3 Members · 6 Replies
  • Peter Ermens
    October 13, 2016 at 9:11 pm
    Hi Roger,
    Bought a few months ago:
    HP Z640, 2 * Xeon E5-2620v4, Z Turbo Drive Z G2 512GB, 64GB, Quadro M4000 8GB, W10 Pro (64).
    I’m using Vegas Pro 13(453)
    The machine works really fine, but I was hoping for a more real VP14. Not a 13.1 as offered now.
    I’m using full HD (Panasonic HDC-HS700) and 4k (DJI Phantom 3 Pro).
    Separatly working perfect in VP13. Together on the timeline, a little bit slower, but with proxies OK.
    Hopes it helps you a bit.
    HP Z640, 2 * Xeon E5-2620v4, 64GB, Quadro M4000 8GB, W10 Pro (64), Vegas Pro 13(453), DS1812+ (+25TB)
  • Roger Bansemer
    October 14, 2016 at 1:45 pm
    Hi Peter,
    Thanks for this information. I’ll check it out but I’m so unfamiliar with all the nomenclature it’s all a bit unclear.
    Is your computer a 10 core, 12 core processor? What is the processor.
    Roger
  • Peter Ermens
    October 16, 2016 at 11:22 am
    Hi Roger,
    Because I read in several places that the number of cores (threads) is important in video-editing I build my pc with two processors (E5-2620 is 8 cores, 16 threads).
    So I got 16 cores (32 threads). I know it’s luxury (I’m a private user), but it’s my hobby.
    You can build your machine with the specs you want on a HP retailersite (workstation configurator).
    HP Z640, 2 * Xeon E5-2620v4, 64GB, Z Turbo Drive Z G2 512GB, Quadro M4000 8GB, W10 Pro (64), Vegas Pro 13(453), DS1812+ (+25TB)
    Panasonic HDC-HS700, DJI Phantom 3 Pro
  • Ole Kristiansen
    October 16, 2016 at 2:15 pm
    Does Vegas Pro support dual cpu and more than 16 threads ?
  • Roger Bansemer
    October 16, 2016 at 8:43 pm
    Good information.
    With this and other info that has been posted I’ve decided to have a local shop build my system as I already have a video card, and a few other items that can be used and upgraded.
    Roger
  • Peter Ermens
    October 17, 2016 at 3:04 pm
    [Ole Kristiansen] “Does Vegas Pro support dual cpu and more than 16 threads ?”
    As far as I can see it, it uses all the threads and the memory (within the limits of VP13 (16 threads and 32Gb memory))
