Activity Forums Adobe Premiere Pro HP Power Supply not working
  • HP Power Supply not working
    Posted by Kenn Schulz on October 10, 2013 at 8:31 pm
    I have an HP Z400 workstation (2010). I wanted to upgrade the power supply and graphics card.
    Existing PSU 475W / GPU nVidia Quadro FX3800 1GB.
    600W PSU from HP did not work (should’ve). MOBO gives 4-beep codes.
    I want to go to (at least) a 2GB GPU and HP compatible PSU (550W?).
    Any suggestions?
    -KS
    Alex Gerulaitis replied 12 years, 7 months ago 2 Members · 1 Reply
  • Alex Gerulaitis
    October 10, 2013 at 9:36 pm
    [Kenn Schulz] “0W PSU from HP did not work (should’ve). MOBO gives 4-beep codes.”
    Possibly a bad power supply? What does the manual say about 4 beeps?
    [Kenn Schulz] “I want to go to (at least) a 2GB GPU and HP compatible PSU (550W?).
    Any suggestions?”
    Non-HP PSU will not work in HP workstations, so the choice is limited to those two.
    K4000 will work with the 475W PSU, perhaps even a K5000. A $250 150W GTX-760 will work as well – probably the best choice.
    — Alex Gerulaitis | Systems Engineer | DV411 – Los Angeles, CA
