Activity Forums Apple Final Cut Pro Legacy HP Dreamcolor and FCP
  • HP Dreamcolor and FCP
    Posted by Darek Sepiolo on June 3, 2010 at 3:52 pm
    I’ve got HP Dreamcolor monitor connected to MacPro via BlackMagic HD LinkPro (display port) to monitor FCP footage. I managed to calibrate the monitor using APS soft and the Xrite/HP calibrator. During the calibration the monitor is connected to MacPro via DVI cable and works as a computer monitor. Then I disconnect one and use BlackMagic to feed the signal. Is the calibrated profile stored in the monitor regardless of the signal source?
    Darek Sepiolo replied 16 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Rafael Amador
    June 3, 2010 at 4:50 pm
    There is a full article of Jeremy garchow about the HP.
    search in the articles.
    rafael
    http://www.nagavideo.com
  • Jeremy Garchow
    June 3, 2010 at 7:46 pm
    What format are you working with?
  • Darek Sepiolo
    June 3, 2010 at 8:10 pm
    I work with XDCAM EX 1080p25 format.
  • Jeremy Garchow
    June 3, 2010 at 8:20 pm
    So what’s your signal path from FCP?
    You are going to need a capture card to do this correctly, and I would recommend the AJA HDP2 over the HD Link. Read this for details:
    https://library.creativecow.net/articles/garchow_jeremy/HP_DreamColor_CRT_Replacement.php
    I have and use a DreamColor and I really like it, BUT it has to be setup properly in order for the DreamColor engine to work.
    Jeremy
  • Darek Sepiolo
    June 3, 2010 at 8:33 pm
    I’ve got DeckLink HD Extreme and HDLink Pro Display Port to monitor FCP signal to Dreamcolor. It works OK.
    Few days ago I’ve got the calibrator and managed to calibrate the monitor. But to do this I had to switch to DVI and connect the monitor to MacPro. The APS created profile for Rec. 709 color space. My question is what happens once I connect the monitor back to display port and the HDLink. Is the profile stored in the monitor? That’s what I red in your article but I’m not sure it applies to my case.
    Thank you Jeremy for your help.
  • Jeremy Garchow
    June 3, 2010 at 8:37 pm
    [Darek Sepiolo] “My question is what happens once I connect the monitor back to display port and the HDLink. Is the profile stored in the monitor? “
    It should be. I don’t use display port, but rather HDMI, and the profile is stored in the monitor. When you go to choose a color space, is your custom profile name available? Can you choose a color space? If not, it’s not setup properly (meaning you aren’t feeding it progressive or RGB. I don’t have experince with HDLink so I don’t know what it’s sending out).
    Jeremy
  • Darek Sepiolo
    June 3, 2010 at 8:52 pm
    The signal is RGB progressive.
    I’m able to choose my custom profile so I guess it’s OK.
    Thank you
