Activity › Forums › Apple Final Cut Pro Legacy › HP Dreamcolor 2480zx / Plunge bar invisible
Antoine D’artemare replied 13 years, 5 months ago 4 Members · 15 Replies
Bernhard G.
September 4, 2010 at 8:04 amToday I tested the configurations once again and i got it work:
The BMD HDLink 3D DP has a little confusing option “Scale to view illegal YUV colors”
(It could be found under “Preferences…”, not in the main tab.)
If it is checked, the problem is solved!
The luminance level adjustment of MXO2 didn’t have any effect!
Neither at feeding HDLink over HDSDI, nor via direct connection to the Dreamcolor via HDMI.Possibility #1:
MXO2 outputs non-conform colors over HDSDI (VERY, very unlikely)Possibility #2:
The said option in the HDLink Utility is nothing else than a confusing named
SMPTE option as known from the AJA utility. (ok … HDLink was build for another purpose…)
I will need to talk to BMD to confirm this.Thank you once again for your help!
Kind regards,
Bernhard
