Activity Forums Adobe After Effects Expressions HowTo: Expression Angle Control dictates the Position of a Null
  • HowTo: Expression Angle Control dictates the Position of a Null
    Posted by Roland R. kahlenberg on October 11, 2013 at 3:21 am
    As the Subject Title says BUT with an additional requirement – the Null can only move along the perimeter/edge of the Comp.
    Cheers
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
    Madli Man replied 12 years, 10 months ago 3 Members · 3 Replies
  • Dan Ebberts
    October 12, 2013 at 11:11 pm
    This is probably too late to help, but I finally found enough time to work this one out.
    a = effect("Angle Control")("Angle")%360;
    if (a < 0) a += 360;
    ar = degreesToRadians(a);
    w = thisComp.width;
    h = thisComp.height;
    g = Math.atan2(h,w);
    if ((ar > Math.PI*2 - g) || (ar <= g)){
    x = w;
    y = (h + w*Math.tan(ar))/2
    }else if ((ar > g) && (ar <= Math.PI - g)){
    x = (w - h*Math.tan(ar - Math.PI/2))/2;
    y = h;
    }else if ((ar > Math.PI - g) && (ar <= Math.PI + g)){
    x = 0;
    y = (h - w*Math.tan(ar - Math.PI))/2;
    }else{
    x = (w + h*Math.tan(ar - 3*Math.PI/2))/2;
    y = 0;
    [x,y]
    Dan
  • Roland R. kahlenberg
    October 14, 2013 at 2:56 am
    Thanks Dan! This worked wonderfully!
    Cheers
    RoRK
  • Madli Man
    November 25, 2013 at 10:06 am
    Hi Dan,
    Just found this thread. This is something i wanted to do long time ago. havent found the trick. 😛
    I have situation here:
    I found this code: that calculate degrees from position.velocity. I use linear to animate position. how can i merge this code to make animated current position to angle control? something like direction.
    Mad
    v = position - position.valueAtTime(time-thisComp.frameDuration);
    radiansToDegrees(Math.atan2(v[1],v[0]))
