Activity › Forums › Adobe Audition › How?
How?
Posted by Jim Williams on March 17, 2017 at 2:26 amI made a sound recording in a room with flourescent lighting, and the transformer noise got in my sound. How might I mark the audio to point out the sound before the speaking begins?
Stefan Schramm replied 9 years, 6 months ago 3 Members · 4 Replies -
Stefan Schramm
March 17, 2017 at 7:26 amIf your audio level is well above the noise level, you can simply use a noise gate.
If the noise level is too high or there are too many gaps in the audio (creating an obnoxious on/off pumping of noise), you need to filter the noise by creating a fingerprint or sample from the noise and then process the audio so that the fingerprinted sample is extracted. Such a process can be made with various tools, such as Wavelab. There are other tools, but I am not aware of any that are free.
Good luck,
StefanVegas 12, Windows 7 Professional
Jim Williams
March 17, 2017 at 1:37 pmThis is the Audition forum, right? I thought the answers posted here would have to do with how to fix the problem in Audition. Is there a video that shows how the hum can be eliminated in Audition? I have used Audacity already, and it did no good. Its not riding over the voice, its just plainly there in the audio. Ideas?
Joseph W. bourke
March 17, 2017 at 8:56 pmWell, Jim, some of them will, some of them won’t – I think Stefan was just trying to be helpful. In Audition I generally find a clear spot where there is only noise, then use Capture Noise Print, which grabs only the noise. Then I save that, and remove it from the master clip; it takes a bit of experimentation to know how agressively you need to apply it. There’s a walkthrough of your options here:
https://helpx.adobe.com/audition/using/noise-reduction-restoration-effects.html
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com -
Stefan Schramm
March 23, 2017 at 8:38 amYes, missed the platform – my bad, sorry.
