Activity › Forums › Apple Final Cut Pro Legacy › How? – 1:66:1 Standard Def DVD – Letterbox on standard and pillarbox on widescreen tvs?
Posted by Devon Powell on April 21, 2011 at 12:51 amI want to make a dvd using standard definition footage. The aspect ratio will be 1:66:1 when cropped. I want for the dvd to show the footage letterboxed on standard tvs and pillarboxed when shown on widescreen televisions.
I am going from final cut pro to compressor to dvd studio pro.
Will someone please give me instructions on how to create footage and make a dvd that will play the footage properly no matter what television set it is viewed on??? I really need help. Thanks.
Jeff Greenberg replied 15 years, 5 months ago 4 Members · 6 Replies -
Michael Gissing
April 21, 2011 at 1:50 am[Devon Powell] “Will someone please give me instructions on how to create footage and make a dvd that will play the footage properly no matter what television set it is viewed on??? I really need help. Thanks.”
You can’t control how other people will set up their DVD player and TV. SD is a cheat in 16:9 because it is using anamorphic squeeze. A 16:9 TV, properly setup will stretch the 4:3 anamorphic image back to 16:9. If someone is viewing on a 4:3 TV, then the DVD player needs to be set to letterbox. If you create a 4:3 letterbox to fit a 16:9 image, then on a widescreen TV it will display both letterbox and pillarboxed.
If you are dealing with 16:9 material, then anamorphic is best. You always have to hope the viewer can setup their system based on the type of TV they have.
Devon Powell
April 21, 2011 at 5:55 amActually, this footage is not anamorphic. It is shot the regular way in the camera. I have letterboxed the footage to an aspect ratio of 1:66:1 (I have my reasons). I was told that I can crop this footage for dvd and that there is a way to make the footage letterboxed on standard television sets and pillarboxed for widescreen television sets (without the letterbox). For example, most dvds you buy play letterboxed on a standard tv and fill the frame or fill most of the frame (depending on the aspect ratio) on widescreen televisions. This is what I want to do.
My footage is not squeezed. It is regular standard def footage that has been made 1:66:1.
How do I do this?
Devon Powell
April 21, 2011 at 8:01 amBasically, I am simply asking how to make a DVD using the software mentioned above, that is “Enhanced for 16:9 TVs.” The footage was not shot using the Anamorphic 16:9 setting of the camera. I intend to crop the video for 1.66 okay?
Now, how do I create a dvd that is “Enhanced for 16:9 TVs?”
Chris Tompkins
April 21, 2011 at 10:46 amYou can fake it with odd sizes by putting black behind your video track.
Choose a standard size to edit.
Shrink/crop video.Chris Tompkins
Video Atlanta LLC -
Chris Tompkins
April 21, 2011 at 12:23 pmWell, DVD files are ONE size for SD-DVD’s
~ 720X480
Then there is anamorphic or not.
Encode your files with Compressor. WideScreen.
You my end up with distorted images.
You are best to create a 720X480 sequence and manipulate your images within that.
Chris Tompkins
Video Atlanta LLC -
Jeff Greenberg
April 22, 2011 at 8:34 pmDevon,
You won’t be able to get exactly what you want without putting two copies on the DVD.
DVD media can be flagged as widescreen (16×9) and will automatically be blown up/letter boxed depending on how they’re individually set up.
You have some odd cropping – 1.66:1 which doesn’t match 16×9 and would have slight black bars on a 16×9 set.
I’d take your video, regardless of what sort of cropping you’ve done, toss it into a 16×9 SD uncompressed sequence, change it’s scale so you’re happy, send to compressor which will generate a 16×9 MPEG2 file. In DVDSP, you’ll have to throw the flag that says ’16×9′
On a 4:3 tv, it will automatically be letterboxed (unless the person has changed their dvd player to blow it up).
On a 16×9, it will be displayed normally.
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
Come See me speak at NAB!
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
