Activity › Forums › Boris FX Particle Illusion › How you use 16:9 ???
Posted by Dennis Fassbaender on May 12, 2008 at 2:20 pmAnybody knows how to work with 16:9 PAL -DV Video?
By opening i have the 4:3 resulution…Can´t find help anywhere 🙁
Alan Lorence replied 18 years, 4 months ago 3 Members · 3 Replies -
Ra-ey Saleh
May 13, 2008 at 1:20 ampI works in square pixels only, so you need to set up your project with the right aspect ratio first.
Press ALT+P for the Project dialog box.
Change your Frame Rate to 25.
Change your Stage Size to 1024 x 576. -
Dennis Fassbaender
May 13, 2008 at 3:44 pmI know the resolution of 1024×576.
But when i import my video file its just 720×576 and doesn´t fit my stage size.
Si i can´t use any effects, because they don´t match my 16:9 footage (or i have to stretch them) … -
Alan Lorence
May 13, 2008 at 7:49 pmI think you need to resize your video to the “square pixel equivalent” size, then bring that resized video into particleIllusion, add your effects, then comp on the original footage.
Alan.
