Activity Forums Adobe After Effects How would you go about achieving this effect?
  • How would you go about achieving this effect?
    Posted by Jeremy Chopra on December 28, 2012 at 10:05 pm
    Hi all,
    I’m trying to think of the best way to go about creating a mini video of my pregnant lady’s bump getting bigger over time?
    I have been filming a sequence of her spinning around a few times each month as her pregnancy develops and want to kind of merge the footage or morph it or similar to show just the belly enlarging over time? if that makes sense?
    What would be the best way to do this that you would suggest? Its shot 1080p on a tripod though the lighting is different each time and her position is somewhat close to similar in each footage but not exactly.
    Any help much appreciated
    http://www.cascadepictures.co.uk
    Darby Edelen replied 13 years, 4 months ago 4 Members · 6 Replies
  • Vishesh Arora
    December 29, 2012 at 7:30 am
    Jeremy
    Liquify Effect(Distort>Liquify) may do the trick.
    Check the Tutorial on how to use it.
    You can animate Distortion Percentage to show the gradual change.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Jeremy Chopra
    December 29, 2012 at 10:26 am
    Hi Vishesh
    thanks for the reply, not sure that effect will do what I’m after, I don’t want to fake it by liquefying, I have shot footage over the months so the belly is bigger in each footage. I don’t need to liquify the belly and fake it I need to morph from each footage to the next but with the movement and the spinning I’m just looking for the best technique for getting it to look seamless and a bit more dynamic than a simple edit!
    thanks
  • Vishesh Arora
    December 29, 2012 at 10:58 am
    Oh sorry Got it now 😀
    In this case You might have to Roto out the bumps(To show the increase in size) and blend them using fadein and fadeout in such a way that it will look seamless.
    You can manually increase the size(of Rotoscoped layer) to show time lapse.
    Vishesh Arora
    Films Rajendra
    Blog:
    Demo Reel(3D):
  • Jeremy Chopra
    December 29, 2012 at 11:36 am
    Yeah roto’ing was the idea I had but was hoping there was a better and less time consuming technique, thanks I will likely go that route unless I discover something else.
  • Tudor “ted” jelescu
    December 29, 2012 at 2:37 pm
    Here’s a post in which I describe a morph technique using only AE native plugins:
    https://forums.creativecow.net/readpost/2/992175
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Darby Edelen
    December 30, 2012 at 1:53 am
    I’ll suggest the Reshape effect as well. Reshape allows you to define a source and target mask and then push the pixels in the image from the source to the target mask. The interface and feature set for this effect are quite different from most other standard AE effects so I recommend reading the documentation on it.
    Primarily getting all of your shots transformed and retimed so that they line up spatially and temporally should get you 80% of the look you’re after.
    Darby Edelen
