Activity Forums Adobe After Effects How would you do this lighting effect?
  • How would you do this lighting effect?
    Posted by Malcolm Desoto on June 14, 2007 at 5:08 am
    So, I created this in photoshop. Now, when I actually do this in AE, the wood floor will be a large separate layer which will move from right to left, simulating movement.
    test BG
    Now, I’d like to do the over head lighting effect on the background in AE so that I can animate it over time and eventually make it disappear.
    Any ideas on how to do this?
    Malcolm Desoto replied 19 years, 3 months ago 3 Members · 4 Replies
  • Steve Roberts
    June 14, 2007 at 2:29 pm
    Make an orange solid, make it a 3D layer, add a light, set it to “spot”, aim it at the solid and animate the spot’s intensity …?
  • Mike Procunier
    June 14, 2007 at 4:42 pm
    or use the CC Spotlight effect… or create a black solid, add an oval mask, invert the mask & feather the crap out of it then adjust the mask shape and layer transparency until it suits your needs.
  • Steve Roberts
    June 14, 2007 at 4:46 pm
    .. or create a solid, add the ramp effect, then set its mode to multiply. Apply curves to the ramp solid and adjust.
    “Many such journeys are possible. Let AE be your gateway.”
  • Malcolm Desoto
    June 14, 2007 at 10:32 pm
    Thanks for the advice. I’ll post the results
