Activity › Forums › Adobe After Effects › How would you do this effect? Can AE do this?
Posted by Reloaded on September 29, 2006 at 11:39 amTake a look at this video https://motionographer.com/media/lobo/early_discarded_oval_test.mov
Is it possible to create it with After Effects?Thanks for any kind of advice.
Steve Roberts replied 19 years, 11 months ago 4 Members · 4 Replies -
Mylenium
September 29, 2006 at 5:37 pmSure. Get 3DStroke from Trapcode, darw elliptical masks, use the Repeater to form a sphgere, wobble the lines up using Turbulent Displace or something similar.
Mylenium
[Pour Myl
Daveyg
September 30, 2006 at 12:44 amim trying what you suggested about repeating but 3d stroke seems to be rotating off center its so weird. i had this problem before with a project but i got away with but now to make the sphere it wont work’
any thoughts
Steve Roberts
September 30, 2006 at 2:35 amMove the mask on the solid until it looks right. 3D stroke will update as you move the mask.
To make sure an elliptical (or rectangular) mask is centered, make it by double-clicking on the elliptical/rectangular mask tool.
Keep in mind that you might need multiple instances of 3D stroke applied to different elliptical masks to get the effect you need. Be prepared for long preview and render times. 🙂
