Activity Forums Adobe After Effects How would YOU do it?
  • How would YOU do it?
    Posted by Lucas Schwartz on April 27, 2018 at 6:33 pm
    Hello Everyone,
    I am trying to create a photo album for my family with the growing flourishes animation style in After Effects.
    Here is an example: https://www.youtube.com/watch?v=sU1mHEg00e4
    I would like to get some suggestions as to how I can create the background for the “Floral Growth” and to display the images without eventually running out of background. The background have to “move along” with the growth.
    Even if I choose a high resolution material as a background it is not large enough to accommodate the growth patterns and about 30 images.
    Suggestions welcome.
    Many thanks,
    Lucas
    Steve Bentley replied 8 years, 4 months ago 2 Members · 2 Replies
  • Lucas Schwartz
    April 28, 2018 at 5:25 am
    Thank you David,
    I will post a link once I have completed the project.
    Kind regards,
    Lucas
  • Steve Bentley
    May 2, 2018 at 9:10 pm
    Hey Lucas,
    Using the compound blur and splines with stroke (or even better, Trapcode’s 3D stroke) is great for this. If you make a stroke in Pshop that has a brush painting the stroke from black to white, the compound blur in AE can use the gradient that follows the line to reveal things.
    Using an animated stroke on a spline in AE can also be used to reveal things.
    You can also use the write-on script or paint to reveal things so that your hand controls the speed of the reveal and it won’t feel so mechanical.
    You can also just do a simple mask that is soft edged and then increase the mask expansion over time to do a “bloom” reveal in areas that have a cluster of leaves or flowers.
