Activity Forums Maxon Cinema 4D How would one go about creating this effect in c4d?
  • How would one go about creating this effect in c4d?
    Posted by Jonathan Alsop on June 27, 2012 at 8:09 am
    https://vimeo.com/34426858
    00:28- 00:30 there is a green sphere that decays. Could anyone point me to a tutorial or give an insight into how this was done.
    Thanks in advance
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    David Alex replied 14 years, 2 months ago 5 Members · 5 Replies
  • Richard Dunstan
    June 27, 2012 at 3:58 pm
    More than likely a couple ways to do that, I would just use an arc spline and toss it into a lathe nurbs, then play with the start angle and end angle, then add thickness by tossing that into a cloth nurbs.
  • Brian Jones
    June 27, 2012 at 5:02 pm
    it was done by using the Boole Object set to A without B subtracting (probably) a cube from the Sphere
  • Greg Burrus
    June 28, 2012 at 11:10 am
    I would say it also is a boole object but there are a number of ways to do it. There is a preset that does this for you pretty easily for $2 https://c4dtools.net/fillex/. There also is an earlier version that was free.
    Greg
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
  • Jonathan Alsop
    June 28, 2012 at 2:14 pm
    Thanks for your help everybody.
    I achieved a fairly satisfactory result by creating booles and moving a large cube through the middle. I also added ambient occulation.
    Will look into the plug in mentioned.
  • David Alex
    July 3, 2012 at 8:23 am
    You could use the free Thrausi plugin to shatter the sphere to pieces…
    https://nitro4d.com/blog/freebie/thrausi/
    Ideas to Creations | Motion Graphics, Visual Effects and Digital Art inspiration, tutorials and much more!
    https://ideastocreations.blogspot.com
