Activity › Forums › Adobe After Effects › How would i set up this colorful expression?
Posted by Richard Garabedain on December 2, 2014 at 12:48 amI put a wiggle on a layer’s fill so that its color changes rapidly. Its for a particle system. The only problem is i get too many black and white frames when i want colors. IS there a better expression, or a little extra expression that will tell the color fill to stay out of the black and white areas.
Jp Pelc replied 11 years, 9 months ago 5 Members · 5 Replies -
Roland R. kahlenberg
December 2, 2014 at 1:49 amWhat does your Expression look like?
Cheers
– RolandTypeGEMs – the Definitive Type Gizmo for AE
https://broadcastgems.com/typegems/Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructorhttps://www.broadcastgems.com/mographintensity_shapestext/
Richard Garabedain
December 2, 2014 at 4:58 amits just a wiggle. I did lower the wiggle amount, that helped and will work well enough if i don’t get a definite answer.
John Cuevas
December 2, 2014 at 2:46 pmYou need to give us more information. Did you apply an effect to the layer, or is it a text layer? What is the layer’s original color, how much of the color spectrum do you want to affect–1 channel, all 3 channels? And to Roland’s query, exactly what expression did you apply to the fill?
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Walter Soyka
December 2, 2014 at 3:09 pm[Richard Garabedain] “IS there a better expression, or a little extra expression that will tell the color fill to stay out of the black and white areas.”
You almost get this for free by starting with the HSL (Hue/Saturation/Lightness) color model instead of RGB. You can convert between them [link] in your expression.
Vary the hue as much as you like; keep the saturation and lightness within ranges to limit blacks and whites.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Jp Pelc
December 2, 2014 at 7:22 pmI would add a wiggle expression to the hue setting in an HSL effect, not a fill.
