Activity › Forums › Boris FX › How would I create half a globe – or less??
  • How would I create half a globe – or less??
    Posted by Marty Simpson on July 11, 2005 at 10:28 pm
    I want to createa globe – no problem…created a square map, brought it in, made sphere – bingo…
    but now I want to drive a bull dozer through the globe and knock out the midsection…so I will need three pieces…top middle and bottom…
    I can create exactly half a sphere in the zspace composite deal…then put it into a model and it goes to heck….
    Also, how can I close off the sphere once created?? I put an oval up to it in a container…but I Cannot map anything like textures to it in the zspace composite vs model container/???
    Marty Simpson replied 21 years, 2 months ago 2 Members · 2 Replies
  • Stephen L. noe
    July 13, 2005 at 5:43 am
    How about duplicating the existing semi sphere and then masking the parts you don’t need when the dozer knocks out the center?
  • Marty Simpson
    July 13, 2005 at 12:13 pm
    Because I cannot map any textures to the half globe I have now.
    I will try masking the three d model container with the sphere, but I have not had any luck masking three d objects…
