Activity › Forums › Adobe After Effects › How would I add Milliseconds to this expression?
  • How would I add Milliseconds to this expression?
    Posted by Jackson Redshaw on May 26, 2014 at 5:54 am
    Hi Guys,
    Just wondering how I would add milliseconds to this expression?
    rate = -1;
    clockStart = 388;
    function padZero(n){
    if (n < 10) return “0” + n else return “” + n
    clockTime = Math.max(clockStart + rate*(time – inPoint),0);
    t = Math.floor(clockTime);
    min = Math.floor((t%3600)/60);
    sec = Math.floor(t%60);
    min + “:” + padZero(sec)
    Jackson
    http://www.youtube.com/MITLRproductions
    Jackson Redshaw replied 12 years, 4 months ago 2 Members · 4 Replies
  • Jackson Redshaw
    May 26, 2014 at 6:14 am
    Hi Dave,
    The frame rate is 25. At the moment, only the minute/s and second/s are displayed on the screen
    Jackson
  • Jackson Redshaw
    May 26, 2014 at 1:14 pm
    I think you misunderstood the question, entirely my fault though.
    The expression is generating a countdown clock on the screen. But only the minute/s and seconds are displayed.
    Thnaks
    Jackson
  • Walter Soyka
    May 26, 2014 at 1:26 pm
    rate = -1;
    clockStart = 388;
    if (n < 10) return "0" + n else return "" + n
    clockTime = Math.max(clockStart + rate*(time - inPoint),0);
    milliseconds = clockTime.toFixed(3).split(".")[1];
    min + ":" + padZero(sec) + "." + milliseconds;
    The magic happens here:
    Here’s a translation. toFixed() is a method that converts a number to a string with a fixed number of decimal places (in this use above, 3). It will pad with zeroes as necessary to maintain this fixed number.
    split() is a method which splits a string into an array of substrings when given a separator. In this case, the separator is a period. For the string “0.123.456”, split(“.”) yields this array of strings: [“0″,”123″,”456”]. We use array indices to access a specific substring.
    In plain English, the above line says convert the clock time to a string including 3 decimal places, then take only the digits after the decimal point and call them “milliseconds.”
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Jackson Redshaw
    May 26, 2014 at 1:28 pm
    Thanks so much Walter. Worked Perfectly!
    Jackson
