Activity Forums Adobe After Effects How would I add a glow around this object.
  • How would I add a glow around this object.
    Posted by Michael Nowakowski on June 27, 2008 at 5:25 am
    Ok I’ll try to keep it brief. I created and object in cinema 4D and imported into after effects. Now I would like to at a very strong and hazy glow around it, kinda like its on fire except blue. I would also like to have the glow leave a trail behind it. Just thought of the best way to visualize it, like a comet!
    How would I go about doing this, and is this something i should be doing in after effects or should i have handled this in cinema 4D?
    Thanks in advance to the COW!
    Darren Stauth replied 10 years, 6 months ago 4 Members · 5 Replies
  • Chris Wright
    June 27, 2008 at 6:24 am
    trapcode particular would work fantastic for this. it has built in fade, time to live, pre-comp support, custom layers and full 3-D rendering with thousands of particles. you could add glow or shine to give it that special punch up. ipod nano tutorial would give you an excellent jump start.
  • Michael Nowakowski
    June 27, 2008 at 6:39 pm
    Thanks a lot. I’ll take a look at the tutorial.
  • Aharon Rabinowitz
    June 30, 2008 at 12:48 pm
    Don;t forget you can also add a simple Photoshop glow inside and outside the edges like you can in Photoshop. Select your layer and choose Layer > Layer Styles and then choose both inner and out glow. Teen set the colors and other properties. This won’t leave the trail, but it will give you a nice base for your glow.
    Aharon Rabinowitz
    Email: arabinowitz (AT) yahoo (DOT) com
    All Bets Are Off Productions, Inc.
    Creative Cow After Effect Podcast
    Internet Killed the Video Star: A Guide to Creating Video for the Web
    July 1, 2008 at 6:37 am
    thanks for that tidbit, those inner and outer glows really helped me fine tune the look without drastically changing the effect.
  • Darren Stauth
    March 14, 2016 at 7:41 pm
    THANK YOU FOR THIS!
    For the longest time I only thought the glow option was available in Effects & Presets 🙂
