Activity Forums Avid Media Composer How we Do Film Editing?
  • How we Do Film Editing?
    Posted by Mohamed Bilal on July 12, 2008 at 3:03 pm
    Friends i am a Digital Video Editor and i want to know how we edit films(16mm,2K,4K etc..)…There is any Video tutorial for learn Film Editing and what are the process in Film Editing.Please help me by giving all related details like How to capture from Film,What are the equipments needed,and what is the good software etc…Thanks alot for Support…
    We humans all are One
    Mohamed Bilal replied 18 years, 2 months ago 3 Members · 5 Replies
  • Job Ter burg
    July 12, 2008 at 3:14 pm
    Hi Mohamed,
    There’s a pretty elaborate segment about fiml projects in the Avid manuals, I guess you could start there.
    Basically, today’s common practice is to transfer film negative to standard def videotape for offline editing. During the telecine session, identification codes are logged. The videotapes are captured into an NLE, together with the log. In the end, physical negative conforming or digital intermediate conforms are done based on an EDL and or cutlists plus the logs.
    So basically, as an editor you are using the same equipment you are using for video editing. The log files are “extra”, and you’ll need to understand either PAL or NTSC pulldown for getting 24fps / 23.98fps footage in 50i or 60i environments.
    You don’t capture straight from film (altough Avid’s Media Station in combination with a telecine could do this).
  • Mohamed Bilal
    July 13, 2008 at 3:43 am
    Thanks for ur Support buddy….if you give me more details or any links to any Tutorial will be more appreciated…anyway i need to now little bit more about it…so please help me to find little more…especially in how to add effects and transitiond in films,and how could it export to film for Final Print etc…There is any E-book ar video Tutor in this subject?Thanks again buddy….
  • Job Ter burg
    July 13, 2008 at 11:38 am
    It’s a bit like asking: how do I build a house?, but I’ll give it a shot.
    In general, after offline editing, a conform needs to be done at final resolution. Traditional conforming would mean the cutting of the actual original camera negative film. That conformed negative film could then be printed for theatrical distribution copies (although usually, intermediate safety copies would be made first). Most effects would have to be made by ordering opticals from optical houses (analog photographic processes), or would have to be done digitally (transfer to digital files first, processed digitally, then burnt to film again). Grading of the image would be done by a color timer, which would determine the exposure levels during printing.
    In the last decade, the digital intermediate process has taken over most conforming. That means that all shots that were used in the edit are retransferred from the original camera negative to a digital file (or sometimes tape), then conformed to the offline. All effects are conformed/added/enhanced there as well. Grading also happens in the diital domain (allowing much more manipulation than is possible in trditional color timing). Afterwards, the digital intermediate will be recorded onto film by machines like an ArriLaser (you put digital files in and it will burn them to 35mm interneg or interpos material). Afterwards, 35mm prints are derived from that and distributed.
    About DI: https://en.wikipedia.org/wiki/Digital_intermediate
    About ArriLaser: https://en.wikipedia.org/wiki/Arrilaser
    Since stuff like the ArriLaser allows for high quality film recoring of digital sources, any digital source is possible. So you can shoot a film on video (SD or HD) or with a digital cinema camera (Red, Sony, Thomson et al.), process everything digitally, then record to film. You could also transfer 16 or 35mm film to (HD) video, edit that, and record it to film. Digital grading can be done on various types of equipment, with different pros and cons (linear versus logarithmic color space).
    In modern cinema post production, many ways lead to Rome, and workflows vary from simple to complex, from expensive to cheap, from high end to low end.
  • Michael Phillips
    July 13, 2008 at 11:49 am
  • Mohamed Bilal
    July 13, 2008 at 4:16 pm
    Thanks alot…I really got a Brief idea now…anyway more details mostly welcome….because other Editors like me can also use these post…Great Work Bros…Thanks Again…Love you….
