Activity › Forums › Adobe Illustrator › How was this file created in AI
Posted by Craig Berman on August 16, 2017 at 5:01 amI thought I knew Illustrator, but I have no idea how this was created. Can anyone tell me how it was done?
Vincent Rosati replied 9 years, 1 month ago 2 Members · 3 Replies -
Vincent Rosati
August 16, 2017 at 1:02 pmBasically, you need a diagonal pattern..
Then use the Blend tool to blend 2 values in the object – Color and opacity.
Then duplicate the blended pattern and flip it, and position on top of the original pattern.Generally..
1) Press ‘M’ then click the artboard to make a box. Enter 80 x 800 PX, or whatever. Apply your base color.
2) Select the rectangle and Object > Skew > -45 deg.
3) Shift + Opt + Drag the object to the side to duplicate it.
4) Set the fill of the duplicate to white ad set the opacity to zero.
5) Select the 2 objects and Object > Blend > Make, then Object > Blend > Settings: Specified Steps.
Here, you’ll see how AI can programmatically generate objects.
Use the Direct or Group select tool to resize or reposition the objects to their desired locations.This should get you started. Let us know if you need any more tips.
Vince
*Please remember to Like an answer if it solves your question or gives you a good idea.
Craig Berman
August 16, 2017 at 4:35 pmThanks for your help, but this isn’t very clear. Should I start with a square? maybe 80×80 not 80×800? I don’t see a skew option, do you mean rotate? I can see getting a blend but I don’t know how the boxes are flush with each other or how the blend goes in two directions, to the side and up. Also not sure how it fits into the artboard.
Vincent Rosati
August 18, 2017 at 9:01 pmHere’s a more thorough explanation..
Project File: 11606_gradpat.zip
Vince
