Activity Forums Adobe After Effects How to zoom map scale by 20% and reduce stroke width by 20% using null object?
  • How to zoom map scale by 20% and reduce stroke width by 20% using null object?
    Posted by Oleksandr Osheko on July 30, 2021 at 1:49 pm
    I am working on animating a map. Each country has a separate layer with its own stoke. Each layer is attached to a null object.
    Is it possible to make it so that when the map scale is increased by 20%, the stroke width is automatically reduced by 20%?
    I can animate each stroke value manually, but I’m just wondering if it can be done automatically? Perhaps there is a special AE expression for such cases?
    I would be grateful for your help.
    Oleksandr Osheko replied 5 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
